ogr2ogr: Command not found
Ryan Ollerenshaw ollerery at ENGR.ORST.EDU
Fri Sep 15 12:22:59 EDT 2006
Sebastian Walter wrote:
> Ryan Ollerenshaw wrote:
>> does anyone know what do i need to do in order to get the gdal
>> commands back into /usr/local/bin/
> You could try, after compiling:
> make install | grep ogr2ogr
I have tried the following as root in /usr/share/gdal-1.3.2/ but none of
the gdal commands that were compiled with my original gdal install are
replaced:
# make clean
#./configure --with-xerces=/root/xerces-c-src_2_7_0/
# make
# make install | grep ogr2ogr
make: *** No rule to make target `install'.  Stop.
and
# make clean
# make
# make install
