AW: [UMN_MAPSERVER-USERS] raster data looks washed out
scottpez scottpez at HOTMAIL.COM
Mon Sep 18 16:32:21 EDT 2006
Arnd or others,
Thank you for the reply. I will try this.
My original data is in Tiff format. Does anyone know if there is a best
setting for the outputformat type and imagemode? If I use png24, what would
be the best imagemode? What are the positives and negatives of using an
outputformat type of png256? Would mapserver be slower producing the image?
I will play around with different settings for this and see if I can get the
colors right and also good performance.
Thanks,
Scott
Arnd Wippermann wrote:
> Hi Scott,
> If the original photo is of 24 bit color you must use png24 or jpeg for
> the
> output with mapserver. That's what I often forget.
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/pinguinale/
> -----Ursprüngliche Nachricht-----
> Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im
> Auftrag von scottpez
> Gesendet: Mittwoch, 13. September 2006 16:08
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: [UMN_MAPSERVER-USERS] raster data looks washed out
> Hi,
> I am trying to serve up a raster dataset in mapserver. The raster dataset
> is
> an aerial orthophoto. When I view this dataset in any program other than
> mapserver  (Imagine, ArcGIS and even FWTools1.0.6 OpenEV_FW program) the
> dataset looks fine. However, when I serve the dataset up through mapserver
> as a wms request, the returned image looks washed out. The colors do not
> seem to be quite right. Also, it seems like the resolution isn't as great
> but then this could simply be because of the washed out colors. Does
> anyone
> know what may be going on here?
> I am not sure the current mapserver version I am using but it is not that
> recent.
> Thanks in advance for any suggestions,
> Scott
> http://www.nabble.com/raster-data-looks-washed-out-tf2265476.html#a6286352
> Sent from the Mapserver - User forum at Nabble.com.
View this message in context: http://www.nabble.com/raster-data-looks-washed-out-tf2265476.html#a6371591
Sent from the Mapserver - User mailing list archive at Nabble.com.
