AW: [UMN_MAPSERVER-USERS] raster data looks washed out
Arnd Wippermann arndw at WTAL.DE
Fri Sep 15 15:48:33 EDT 2006
Hi Scott,
If the original photo is of 24 bit color you must use png24 or jpeg for the
output with mapserver. That's what I often forget.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/pinguinale/
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Im
Auftrag von scottpez
Gesendet: Mittwoch, 13. September 2006 16:08
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: [UMN_MAPSERVER-USERS] raster data looks washed out
I am trying to serve up a raster dataset in mapserver. The raster dataset is
an aerial orthophoto. When I view this dataset in any program other than
mapserver  (Imagine, ArcGIS and even FWTools1.0.6 OpenEV_FW program) the
dataset looks fine. However, when I serve the dataset up through mapserver
as a wms request, the returned image looks washed out. The colors do not
seem to be quite right. Also, it seems like the resolution isn't as great
but then this could simply be because of the washed out colors. Does anyone
know what may be going on here?
I am not sure the current mapserver version I am using but it is not that
recent.
Thanks in advance for any suggestions,
Scott
View this message in context:
http://www.nabble.com/raster-data-looks-washed-out-tf2265476.html#a6286352
Sent from the Mapserver - User forum at Nabble.com.
