unable to load dll[mapscript] ....help me...
Wiharto Hernowo wiharto_hernowo at YAHOO.COM
Tue Sep 19 06:39:32 EDT 2006
hi list,
Right now i'm developing a web application using mapserver to build a planning of  electrical network distribution in ASP.NET using C# language and Oracle 9 i R2. And i have worked for 5 months and my mapscript_csharp.dll and mapscript.dll component is in good condition. And then 2 days ago my notebook was broken and fortunetly  i could save my data. But after it has been fixed, i do a stupid things that makes my component can't run. I do uninstall the Oracle Client on my Notebook. And i think what i do it doesn't effect the others but the result is my component can't work properly and if i run on my visual Studio .net 2003 always open the error result "unable to load dll[mapscript]".
And then i search in google and in the list.umn.edu. And i do it all the advice from the forum and the google. But the result is the same. I try to format all the drives on my notebook and the result is the same. I recompile all the component both in visual Studio.NET 2003 or Visual Studio 6 and the same all the result is "Unable to load DLL[mapscript]" . I try to build path in the windows to the dll and the result is the same. And then i put the mapscript.dll and the others except mapscript_csharp.dll in the System32 in the windows but still the same.
And right now i'm stuck, i dont know what to do. And if i can get answer for my problem, i will sent my source code and my paper about my application that i use in ICTS (Information And Communication Technology Seminar in Surabaya ,Indonesia) to the forum. I do this cause i think this is my only way to thank you to the forum and maybe i will get reply about my application for improving and the others.
Thank you in advance for any help.
Greetings,
Wiharto hernowo
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060919/3e4ab5eb/attachment.html
