unable to load dll[mapscript] ....help me...
Tamas Szekeres
szekerest at GMAIL.COM
Tue Sep 19 07:20:01 EDT 2006
I guess one of the subsequent dll-s could not be loaded by your
application. You might want to use a file monitiring tool (like
SysInternals filemon) to make sure that all of the dll-s could be
loaded properly.
It would be also helpful to recompile the latest version and confirm that the
'nmake -f makefile.vc test' is running on your system properly.
For more information visit:
http://mapserver.gis.umn.edu/docs/howto/mapscriptcscompile
Downloading the Windows buildkit would be an useful starting point to
make the compilation and get all of the required dll-s for the
application.
Best Regards
Tamas Szekeres
2006/9/19, Wiharto Hernowo <wiharto_hernowo at yahoo.com>:
> hi list,
> Right now i'm developing a web application using mapserver to build a
> planning of electrical network distribution in ASP.NET using C# language
> and Oracle 9 i R2. And i have worked for 5 months and my
> mapscript_csharp.dll and mapscript.dll component is in good condition. And
> then 2 days ago my notebook was broken and fortunetly i could save my data.
> But after it has been fixed, i do a stupid things that makes my component
> can't run. I do uninstall the Oracle Client on my Notebook. And i think what
> i do it doesn't effect the others but the result is my component can't work
> properly and if i run on my visual Studio .net 2003 always open the error
> result "unable to load dll[mapscript]".
> And then i search in google and in the list.umn.edu. And i do it all the
> advice from the forum and the google. But the result is the same. I try to
> format all the drives on my notebook and the result is the same. I recompile
> all the component both in visual Studio.NET 2003 or Visual Studio 6 and the
> same all the result is "Unable to load DLL[mapscript]" . I try to build path
> in the windows to the dll and the result is the same. And then i put the
> mapscript.dll and the others except mapscript_csharp.dll in the System32 in
> the windows but still the same.
> And right now i'm stuck, i dont know what to do. And if i can get answer for
> my problem, i will sent my source code and my paper about my application
> that i use in ICTS (Information And Communication Technology Seminar in
> Surabaya ,Indonesia) to the forum. I do this cause i think this is my only
> way to thank you to the forum and maybe i will get reply about my
> application for improving and the others.
> Thank you in advance for any help.
> Greetings,
> Wiharto hernowo
> ________________________________
> Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+
> countries) for 2¢/min or less.
