Question: ArcGIS Server using PostgreSQL/PostGIS
Till Adams adams at TERRESTRIS.DE
Thu Sep 21 04:13:43 EDT 2006
Luca,
ok. Never tried it again after i had three crashes some time ago :-(
Till
Luca Manganelli schrieb:
> On 9/21/06, Till Adams <adams at terrestris.de> wrote:
>> To your question: There is an externsion to ArcGIs 8 called "PgArc"
>> (->sourceforge). But first it is a kind of "unsufficient hack", because
>> it does not make ArcGIS read PostGIS directly, it uses the
>> shp2pgsql/pgsql2shp extensions to generate a shape, which then is used
>> by ArcGIS and written back.
>> Second since esri changed the object model between arcgis 8 and 9 it
>> does not work with the 9-er stuff.
> You're wrong. It works with ArcGIS 9. But it is really SLOW.
*  released: AmeiN! ArcMap-Export-2-UMN  *
*        LiveLinux 'WebGIS on CD'        *
*        http://www.terrestris.de        *
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
