mapserv and ogr2ogr reprojection (Google Earth)
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Sep 25 11:15:45 EDT 2006
Hi list,
first of all, maybe this would be better addressed at the gdal-dev list as well.
Using Jan Hartman's PROJ.4 parameters for EPSG:28992 (http://postgis.refractions.net/pipermail/postgis-users/2005-November/009894.html), we successfully got Dutch national grid data to match the aerial photography of Google Earth.
We used Mapserver WFS and ogr2ogr (GML input, KML output) to transform the data.
If we transform using ogr2ogr and provide -s_srs with the exact same PROJ.4 string and t_srs of EPSG:4326, the overlay is not correct.
Any ideas what could be causing this? All testing was done using FWTools 1.0.5 on Windows XP.
Another question:
-how hard would it be to have the same OUTPUTFORMAT mechanism for vector (Mapserver WFS/OGR), so that output formats of OGR could be outputted by Mapserver WFS?
Thanks in advance.
Best regards,
Bart van den Eijnden
drs. A.J. van den Eijnden
adviseur
Productteam Applicaties Geo-Informatie
Rijkswaterstaat Adviesdienst Geo-informatie en ICT
Postbus 5023, 2600 GA Delft
Derde Werelddreef 1, 2622 HA Delft
Telefoon: (015) 275 75 75
E-mail b.vdeijnden at agi.rws.minvenw.nl
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
