mapserv and ogr2ogr reprojection (Google Earth)
Frank Warmerdam warmerdam at POBOX.COM
Mon Sep 25 11:55:53 EDT 2006
Eijnden, Bart van den (AGI) wrote:
> Hi list,
> first of all, maybe this would be better addressed at the gdal-dev list as
> well.
> Using Jan Hartman's PROJ.4 parameters for EPSG:28992
> (http://postgis.refractions.net/pipermail/postgis-users/2005-November/009894.html),
> we successfully got Dutch national grid data to match the aerial
> photography of Google Earth.
> We used Mapserver WFS and ogr2ogr (GML input, KML output) to transform the
> data.
> If we transform using ogr2ogr and provide -s_srs with the exact same PROJ.4
> string and t_srs of EPSG:4326, the overlay is not correct.
> Any ideas what could be causing this? All testing was done using FWTools
> 1.0.5 on Windows XP.
Bart,
It is not immediately clear to me why this would not work properly.  I
did check the PROJ.4 coordinate system in question, and it appears to
go through OGR's internal SRS conversions without any damage.
If you could submit a bug report against OGR with all the details I will
dig into it.  In particular what I would like to see is a point transformed
through ogr2ogr producing a different output value than the same point
transformed using cs2cs.   I gather your central premise is that with
cs2cs you got the expected results, but you didn't see the same results with
ogr2ogr, right?
> Another question:
> -how hard would it be to have the same OUTPUTFORMAT mechanism for vector
> (Mapserver WFS/OGR), so that output formats of OGR could be outputted by
> Mapserver WFS?
It would be a fairly substantial effort I think.  I gather we would need
something roughly analygous to mapgml.c that can write via an OGR driver,
and then various machinery connecting up format selection in the wfs output.
Perhaps a 2-3 week development effort.
I think we would also need a mechanism to identify files to "bundle up"
in a zip or something similar for multi-file formats such as shape, or
mapinfo.
But I can see that this would be an interesting capability.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
