mapserv and ogr2ogr reprojection (Google Earth)
Eijnden, Bart van den (AGI) b.vdeijnden at AGI.RWS.MINVENW.NL
Tue Sep 26 03:51:57 EDT 2006
Thanks Frank, I have opened up a bug in the GDAL/OGR bugzilla for this:
http://bugzilla.remotesensing.org/show_bug.cgi?id=1307
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: Frank Warmerdam [mailto:warmerdam at pobox.com]
Verzonden: maandag 25 september 2006 17:56
Aan: Eijnden, Bart van den (AGI)
CC: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] mapserv and ogr2ogr reprojection
(Google Earth)
Eijnden, Bart van den (AGI) wrote:
> Hi list,
> first of all, maybe this would be better addressed at the gdal-dev list as
> well.
> Using Jan Hartman's PROJ.4 parameters for EPSG:28992
> (http://postgis.refractions.net/pipermail/postgis-users/2005-November/009894.html),
> we successfully got Dutch national grid data to match the aerial
> photography of Google Earth.
> We used Mapserver WFS and ogr2ogr (GML input, KML output) to transform the
> data.
> If we transform using ogr2ogr and provide -s_srs with the exact same PROJ.4
> string and t_srs of EPSG:4326, the overlay is not correct.
> Any ideas what could be causing this? All testing was done using FWTools
> 1.0.5 on Windows XP.
Bart,
It is not immediately clear to me why this would not work properly.  I
did check the PROJ.4 coordinate system in question, and it appears to
go through OGR's internal SRS conversions without any damage.
If you could submit a bug report against OGR with all the details I will
dig into it.  In particular what I would like to see is a point transformed
through ogr2ogr producing a different output value than the same point
transformed using cs2cs.   I gather your central premise is that with
cs2cs you got the expected results, but you didn't see the same results with
ogr2ogr, right?
> Another question:
> -how hard would it be to have the same OUTPUTFORMAT mechanism for vector
> (Mapserver WFS/OGR), so that output formats of OGR could be outputted by
> Mapserver WFS?
It would be a fairly substantial effort I think.  I gather we would need
something roughly analygous to mapgml.c that can write via an OGR driver,
and then various machinery connecting up format selection in the wfs output.
Perhaps a 2-3 week development effort.
I think we would also need a mechanism to identify files to "bundle up"
in a zip or something similar for multi-file formats such as shape, or
mapinfo.
But I can see that this would be an interesting capability.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
