Labeling from a MySQL Datasource
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Tue Sep 26 05:46:48 EDT 2006
Ian Erickson wrote:
> Does anyone have an example of how to label a MapServer layer with the
> results of a JOIN directive.  Is this even possible using the LABELITEM
> parameter?  Using PHP MapScript and MapServer 4.8.
Ian,
I fear it's not possible to do what you'd like by the way you mention.
AFAIK and according to
http://mapserver.gis.umn.edu/docs/reference/mapfile/join fields joined
through a JOIN directive can not be used to affect the look of a map. In
fact, there's no working way to reference fields from a JOIN anywhere
inside the mapfile. They can be referenced inside templates for HTML
display only.
You could however draw them dynamically from inside PHP.
Best regards,
Andreas
