Reprojecting a layer using gdaltindex
Frederico Lucca fredlucca at GMAIL.COM
Tue Sep 26 08:50:49 EDT 2006
Hello list,
Can I reproject a image that is inside a layer using tileindex?
My problem is that I need to show a ECW that is in Corrego Alegre Datum.
First of all I tried to use
PROJECTION
   "init=epsg:4225"
END
without success.
Than I tried to use gdalwarp to convert it to WGS84 that is my map Datum,
but I can't write ECW format, why not?
So, the only solution I found is convert using gdalwarp exporting as GTiff,
but the image size is very large.
I have many photos and want to use only a layer if is possible.
There is a solution?
Thanks,
Fred
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060926/f39d72ec/attachment.html
