Adding point to ESRI Personal Geodatabase through ODBC
Frank Warmerdam warmerdam at POBOX.COM
Tue Sep 26 09:58:04 EDT 2006
Delfos, Jacob wrote:
> Hi All,
> I was wondering if anyone has knows how to add a point feature to an
> ESRI personal geodatabase, without using ESRI software (ideally through
> SQL). The spatial column is "long binary data" according to MS Access.
> I'm assuming I'd also have to update the spatial index. I'm using PHP,
> which I believe supports binary data through ODBC.
> I'm assuming it's possible, but I'm not sure yet how. Alternatively,
> I'll have to use ODBC/OVF. Not a drama, but I'd like to keep it all in
> one format.
Jacob,
The format of the geometry is based on the shapefile format, and there
is code to decode it in OGR (for the geodatabase driver).  I think it
would be hard to construct these geometries properly using SQL, but then
my SQL-fu is weak.
I've never actually worked out how the spatial index works, so updating that
might be quite challenging.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
