using alt tag to do mouse over
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Sep 27 09:24:16 EDT 2006
Beheen,
Take a look at the ImageMap HowTo:
http://mapserver.gis.umn.edu/docs/howto/imagemaps
In section 3.1, it shows how to substitute the value from the shapefile
field 'NAME' into each imagemap element.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Trimble, Beheen
Sent: Wednesday, September 27, 2006 6:20 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] using alt tag to do mouse over
Hi Kristian,
Alt or Title, still I need it to be a mapserver/cgi variable that when I
submit the request, extracts the site_name from the shapefile. I don't
know the site_name before hand. I can not hard code the value.
Thanks
Beheen
Behalf Of Thy, Kristian
Sent: Wednesday, September 27, 2006 4:09 AM
> From: Trimble, Beheen
> I want to use alt tag in my template to show an attribute of
> the active layer.
As an aside, the alt text doesn't show as a tooltip in Firefox, because
that's not what the 'alt' attribute is for. Use the attribute 'title'
for that, if you care about web standards.
regards,
Kristian
This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly agreed
in writing, nothing stated in this communication shall be legally
binding.
