What is ids in imagemap example?
Randy James rjames57 at YAHOO.COM
Thu Sep 28 17:12:10 EDT 2006
all my variables get populated from the template file, on mine i called it template.html, yours looks like its county_example.html.
  randy
"Trimble, Beheen" <btrimble at sfwmd.gov> wrote:
        v\:* {behavior:url(#default#VML);}  o\:* {behavior:url(#default#VML);}  w\:* {behavior:url(#default#VML);}  .shape {behavior:url(#default#VML);}        st1\:*{behavior:url(#default#ieooui) }                Randy,
  It is ids  as in EXPRESSION ('[COUN]' in '%ids%')
  I know COUN is an attribute in county shape file but I  don’t know where the ‘ids’ variable is coming from and how it gets populated!
  Thanks
  Beheen
Sent: Thursday, September 28, 2006 5:03 PM
To: Trimble, Beheen
Cc: Mapserver Users
Subject: Re: [UMN_MAPSERVER-USERS] What is ids in imagemap example?
    i believe id is the name of a variable, the two % show the start and the end of the variable.
    check out
    http://umn.mapserver.ch/MapServer/en/syntax.htm
    randy
"Trimble, Beheen" <btrimble at SFWMD.GOV> wrote:
      Hey People,
    I am still trying to make the mouseover works in my application!
    Do you know what is %ids% in below map?  Where this is defined?
    Thanks
    Beheen
MAP
  NAME "TEST"
  SIZE 380 450
  EXTENT  180000 4816000 773000 5474000
  UNITS METERS
  IMAGECOLOR 252 252 252
  SHAPEPATH "/r01/data/drs"
  FONTSET "/usr/local/mapserver/fonts/fonts.list"
  WEB
    HEADER "templates/imagemap_header_example.html"
    FOOTER "templates/imagemap_footer_example.html"
    IMAGEPATH "/usr/local/www/docs_maps/tmp/"
    IMAGEURL "/tmp/"
  END
  QUERYMAP
    STATUS ON
    STYLE NORMAL
  END
  LAYER
    NAME county
    STATUS OFF
    DATA "data/bdry_counpy2_gen500"
    TYPE
 POLYGON
    # LABELITEM "CTY_ABBR"
    CLASS
      STYLE
        COLOR "#BD9E5D" # "#A27528"
        OUTLINECOLOR 50 50 50
      END
    END
    CLASS
      COLOR 255 255 255
    END
    TEMPLATE "templates/county_example.html"
  END # counties
END
  Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail.
Stay in the know. Pulse on the new Yahoo.com.  Check it out.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060928/367b7e11/attachment.html
