What is ids in imagemap example?
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Thu Sep 28 19:27:59 EDT 2006
These are variables that can be set via the mapserver cgi interface or
via a cookie. So in your case you could do something like:
http://localhost/cgi-bin/mapserv?mode=map&map=....&ids=123,456,789
and this would substitute into the %ids% string:
EXPRESSION ('[COUN]' in '123,456,789')
The exact syntax obvious needs to match the correctly to its usage.
-Steve W
Trimble, Beheen wrote:
> Randy,
> It is ids  as in EXPRESSION ('[COUN]' in '%ids%')
> I know COUN is an attribute in county shape file but I  don’t know where
> the ‘ids’ variable is coming from and how it gets populated!
> Thanks
> Beheen
> * From: * Randy James [mailto:rjames57 at yahoo.com]
> *Sent:* Thursday, September 28, 2006 5:03 PM
> *To:* Trimble, Beheen
> *Cc:* Mapserver Users
> *Subject:* Re: [UMN_MAPSERVER-USERS] What is ids in imagemap example?
> i believe id is the name of a variable, the two % show the start and the
> end of the variable.
> check out
> http://umn.mapserver.ch/MapServer/en/syntax.htm
> randy
> */" Trimble, Beheen " <btrimble at SFWMD.GOV>/* wrote:
>     Hey People,
>     I am still trying to make the mouseover works in my application!
>     Do you know what is %ids% in below map?  Where this is defined?
>     Thanks
>     Beheen
>      MAP
>        NAME "TEST"
>        SIZE 380 450
>        EXTENT  180000 4816000 773000 5474000
>        UNITS METERS
>        IMAGECOLOR 252 252 252
>        SHAPEPATH "/r01/data/drs"
>        FONTSET "/usr/local/mapserver/fonts/fonts.list"
>        WEB
>          HEADER "templates/imagemap_header_example.html"
>          FOOTER "templates/imagemap_footer_example.html"
>          IMAGEPATH "/usr/local/www/docs_maps/tmp/"
>          IMAGEURL "/tmp/"
>        END
>        QUERYMAP
>          STATUS ON
>          STYLE     NORMAL
>        END
>        LAYER
>          NAME county
>          STATUS OFF
>          DATA "data/bdry_counpy2_gen500"
>          TYPE
>       POLYGON
>          # LABELITEM "CTY_ABBR"
>          CLASS
>            STYLE
>              COLOR "#BD9E5D" # "#A27528"
>              OUTLINECOLOR 50 50 50
>            END
>          END
>          CLASS
>            COLOR 255 255 255
>          END
>          TEMPLATE "templates/county_example.html"
>        END # counties
>      END
> Do you Yahoo!?
> Everyone is raving about the all-new Yahoo! Mail.
> <http://us.rd.yahoo.com/evt=42297/*http:/advision.webevents.yahoo.com/mailbeta>
