Polar Stereographic projection Extent
Ryan Ollerenshaw ollerery at ENGR.ORST.EDU
Fri Sep 29 11:59:25 EDT 2006
I am having a bit of trouble figuring out the extent I should use to
display the entire northern hemisphere using the Polar Stereographic
projection.  The best that i have been able to come up with is:
EXTENT 3000 2000 4000000 3000000
but this only displays the right half of the norther hemisphere, how can
i display the full 360 degrees of the northern hemisphere all at one
time?  When using a polar projection i am not sure what the extent
numbers actually represent.  They cant be corner points because the
display should be a circle, so what are they offsets from?  Any clarity
that someone can provide on how to use polar projection would be very
helpful. Thanks.
PROJECTION
     "proj=stere"
        "lat_ts=75"
        "north"
        "lat_0=90"
  END
