raster output streched at CGI Query mode
Richard Greenwood richard.greenwood at GMAIL.COM
Fri Sep 29 23:06:10 EDT 2006
On 9/29/06, Eduardo Patto Kanegae <epk.lists at gmail.com> wrote:
> Hi,
> I'm running MapServer 4.10.0RC1 on Fedora 5 with mapserver built with:
> MapServer version 4.10.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=POINT_Z_M INPUT=TIFF INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> When I'm browsing the application it displays me everything ok. All
> shapefile layers and tif layers are shown correclty.
> But when I change to nquery mode and then hit an area, querymap is shown but
> raster images appears with distortion.
> All dataset are UTM-SAD 69 23S, so no projection is set. I also noted this
> problem with another application with different projections at each layer.
> I put two screenshots of the error at:
>  http://www.webmapit.com.br/debug/ms_map-mode.png
> http://www.webmapit.com.br/debug/ms_map-query.png - note
> the red lines I drawn...
> Is that a bug?
I had encountered something that appears to be similar and posted a bug report:
   http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1463
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
