raster output streched at CGI Query mode
Eduardo Patto Kanegae epk.lists at GMAIL.COM
Fri Sep 29 10:00:20 EDT 2006
I'm running MapServer 4.10.0RC1 on Fedora 5 with mapserver built with:
MapServer version 4.10.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=THREADS SUPPORTS=GEOS
SUPPORTS=POINT_Z_M INPUT=TIFF INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
When I'm browsing the application it displays me everything ok. All
shapefile layers and tif layers are shown correclty.
But when I change to nquery mode and then hit an area, querymap is shown but
raster images appears with distortion.
All dataset are UTM-SAD 69 23S, so no projection is set. I also noted this
problem with another application with different projections at each layer.
I put two screenshots of the error at:
http://www.webmapit.com.br/debug/ms_map-mode.png
http://www.webmapit.com.br/debug/ms_map-query.png - note the red lines I
drawn...
Is that a bug?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060929/3049f9b9/attachment.html
