version 4.10 Beta 3
Graham Davis gdavis at REFRACTIONS.NET
Fri Sep 29 12:29:52 EDT 2006
While testing v 4.10 beta 3 I noticed that some of the SQL in my MAP
file was no longer working.  I figured out that the column names were
now case sensitive (ie: I was trying to SELECT the column assetId when
it is actually assetid in the PostgreSQL database).  This LAYER was no
longer drawn in the returned map image.  It worked previously with the
last non-beta version of mapserver.  Changing my SELECT statement so
that the casing matched fixed the problem for the beta.
I just wanted to confirm that this is a change that will be in the
new/next non-beta version of mapserver.  I'll need to go and re-check
many of my MAP files when converting.  Thanks,
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
