Polar Stereographic projection Extent
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Fri Sep 29 14:24:30 EDT 2006
Vincent J. Troisi wrote:
> Ryan Ollerenshaw wrote:
>> I am having a bit of trouble figuring out the extent I should use to
>> display the entire northern hemisphere using the Polar Stereographic
>> projection. The best that i have been able to come up with is:
>> EXTENT 3000 2000 4000000 3000000
>> but this only displays the right half of the norther hemisphere, how
>> can i display the full 360 degrees of the northern hemisphere all at
>> one time? When using a polar projection i am not sure what the
>> extent numbers actually represent. They cant be corner points
>> because the display should be a circle, so what are they offsets
>> from? Any clarity that someone can provide on how to use polar
>> projection would be very helpful. Thanks.
>> PROJECTION "proj=stere"
>> "lat_ts=75"
>> "north"
>> "lat_0=90"
>> END
> We've been successful with
> -9036842.762, -9036842.762, 9036842.762, 9036842.762
when i try this extent i get a white circle that takes up most of the
screen and i can only see a very small piece of my data in a half moon
shape on the right edge of my window. Is anyone able to explain what
the extent numbers actually mean when using a polar projection? Why am
i getting a large white circle with my data wrapped around, and how do i
decrees the size of this central circle to zero so my pole comes
together to a single point?
