version 4.10 Beta 3
Graham Davis gdavis at REFRACTIONS.NET
Fri Sep 29 16:07:07 EDT 2006
HI Frank,
That sounds correct, quotes will make the columns case sensitive.
Thanks for the confirmation!
Graham.
Frank Warmerdam wrote:
> Graham Davis wrote:
>> While testing v 4.10 beta 3 I noticed that some of the SQL in my MAP
>> file was no longer working.  I figured out that the column names were
>> now case sensitive (ie: I was trying to SELECT the column assetId
>> when it is actually assetid in the PostgreSQL database).  This LAYER
>> was no longer drawn in the returned map image.  It worked previously
>> with the last non-beta version of mapserver.  Changing my SELECT
>> statement so that the casing matched fixed the problem for the beta.
>> I just wanted to confirm that this is a change that will be in the
>> new/next non-beta version of mapserver.  I'll need to go and re-check
>> many of my MAP files when converting.  Thanks,
> Graham,
> I'm guessing this relates to this commit message in mappostgis.c:
>  * Revision 1.72  2006/05/09 22:35:41  pramsey
>  * Added quotes around field names being retrieved by query requests.
> (Bug 1536)
> So, I think that as long as we are quoting the field names in POSTGIS
> style connections, they will likely be case sensitive - now and going
> forward.
> Best regards,
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
