Hatching a polygon
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Mon Apr 2 21:01:25 EDT 2007
Hi Gary,
I noticed with hatching (and other polygon fills) that you have to
specify:
TRANSPARENCY 100 # this means fully opaque
If you don't, you will get a white fill underneath your hatch. It
doesn't make sense (maybe I missed something), but at least it's easy to
get around.
Hope this helps,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Gary Watry
> Sent: 2 April 2007 19:15
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Hatching a polygon
> I know how to hatch a polygon,
> but what I want to do is
> 1. if I create a polygon fill using
> in the symbol.sym file
> # Cross Hatch
> SYMBOL
> NAME "hatch"
> TYPE HATCH
> END
> and in the mapfile
> STYLE
> SYMBOL 'hatch'
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> ANGLE 45
> SIZE 10
> WIDTH 3
> END
> How do I make the hatch so I can see the layer underneath the polygon
> instead of the white color between the hatch lines??
> 2 Is it possible to make a polygon fill semi-transparent so
> you can see
> the layer underneath the polygon through the fill??
> The information transmitted is intended solely for the person
> or entity for which it is addressed and may contain
> confidential and/or privileged information. Any review,
> retransmission, dissemination or other use of, or taking of
> any action in reliance upon this information by persons or
> entities other than the intended recipient is prohibited. If
> you received this email in error, please contact the sender
> and delete the material from your computer.
> Gary L. Watry
> GIS Coordinator
> Center for Ocean-Atmospheric Prediction Studies
> FSU / COAPS
> Johnson Building, RM 231
> 2035 East Paul Dirac Drive
> Tallahassee, Florida 32306-2840
> Phone (850) 645-7457
> E-Mail: watry at coaps.fsu.edu
This email and any attachments are intended solely for the named recipient and are confidential. The copying or distribution of them or any information they contain by anyone other than the named recipient is prohibited. If you have received this document in error, please notify the sender and delete all copies from your computer system and destroy all hard copies. It is the recipient's responsibility to check this email and any attachments to this email for viruses before use.
