Problem: ANGLEITEM and TRANSPARENT
Richard Duivenvoorde
rdmailings at DUIF.NET
Fri Apr 6 10:05:21 EDT 2007
Hi All,
I have some troubles also with transparent symbols
server version:
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SU
PPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPP
ORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAP
EFILE DEBUG=MSDEBUG
using transparent png AND output as a png (AND using 'TRANSPARENCY
ALPHA' as Daniel proposed), results in transparent image symbols, but
ONLY for the 90, 180 and 270 degrees rotation ???
See attachement: all the same symbol, rotated different degrees.
So it looks like Peter's 'overlapping' problem seems to me not an
overlapping symbol, but more an 'amount of rotation symbol'.
Maybe this 'conclusion' is helpfull?
It would be nice if rotating image symbols will be fixed one day.
Grtz
Peter Sykora wrote:
>> I didn't follow the previous posts in this thread, but just in case I
>> thought I'd ask: did you try setting TRANSPARENCY ALPHA in your layer?
> Hi Daniel,
> thanks for your hint, but it had no effect on my results. I think the
> TRANSPARENCY ALPHA is useful to create transparent 24 bit images, but I
> can´t image that it has any relevance with this specific problem when images
> are rotated. Again, the transparency works fine when symbols are not
> rotated, so the problem must be somewhere else.
> Peter
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070406/79c6dcb8/rotatedSymbol2.gif
