Virtual Tables
Brent Fraser
bfraser at GEOANALYTIC.COM
Wed Apr 18 14:14:01 EDT 2007
MessageKevin,
Try putting the full path to the mapsonline.csv between the <SrcLayer> tags.
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Wednesday, April 18, 2007 12:09 PM
Subject: Re: [UMN_MAPSERVER-USERS] Virtual Tables
I am using a chameleon app.and getting the following error:
"Error rendering map image:
A fatal error occurred drawing the map"
I did try setting the STATUS to default with no change.
Kevin
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Wednesday, April 18, 2007 2:04 PM
To: Kevin Flanders; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] Virtual Tables
How is it failing?
Are you getting an error message?
Are you specifically calling the layer by name in the URL or post request, or have you tried setting STATUS to DEFAULT?
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Kevin Flanders
Sent: Wednesday, April 18, 2007 12:41 PM
Subject: [UMN_MAPSERVER-USERS] Virtual Tables
I would like to map a virtual table, and I am told I can do it without declaring an ODBC.using the following mapfile layer definition:
LAYER
NAME "Fire Data"
GROUP "Fire Data"
STATUS on
TYPE point
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='firegis'>
<SrcLayer>mapsonline.csv</SrcLayer>
<GeometryField encoding='PointFromColumns' x='XCOORD' y='YCOORD'/>
<GeometryType>wkbPoint</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>"
TEMPLATE "ttt"
TOLERANCE 4
CLASS
NAME "Fire Data"
SYMBOL "circle"
OUTLINECOLOR 80 80 80
COLOR 219 0 0
SIZE 12
END
END
But this fails. Do I need an ODBC..or is it true I can access a text file directly in this manner. The data is being placed with all my other shapefiles (ie. in the same folder).
Also, can the .csv file just as easily be a .txt file..and can the entries have quotations around them?
Kevin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070418/481d7951/attachment.html
