Virtual Tables
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Apr 18 14:20:46 EDT 2007
I would simplify it down for testing purposes.
If you don't already have it, download FWTools and use shp2img against
your mapfile to see if you can get it to draw.
To narrow it even further, I would start by running ogrinfo against
your virtual datasource to see if you can get data out of it.
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Kevin Flanders
Sent: Wednesday, April 18, 2007 1:09 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Virtual Tables
I am using a chameleon app...and getting the following error:
"Error rendering map image:
A fatal error occurred drawing the map"
I did try setting the STATUS to default with no change...
Kevin
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Wednesday, April 18, 2007 2:04 PM
To: Kevin Flanders; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] Virtual Tables
How is it failing?
Are you getting an error message?
Are you specifically calling the layer by name in the URL or
post request, or have you tried setting STATUS to DEFAULT?
David.
Sent: Wednesday, April 18, 2007 12:41 PM
Subject: [UMN_MAPSERVER-USERS] Virtual Tables
I would like to map a virtual table, and I am told I can
do it without declaring an ODBC...using the following mapfile layer
definition:
LAYER
NAME "Fire Data"
GROUP "Fire Data"
STATUS on
TYPE point
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer
name='firegis'>
<SrcLayer>mapsonline.csv</SrcLayer>
<GeometryField
encoding='PointFromColumns' x='XCOORD' y='YCOORD'/>
<GeometryType>wkbPoint</GeometryType>
</OGRVRTLayer>
</OGRVRTDataSource>"
TEMPLATE "ttt"
TOLERANCE 4
CLASS
NAME "Fire Data"
SYMBOL "circle"
OUTLINECOLOR 80 80 80
COLOR 219 0 0
SIZE 12
END
END
But this fails. Do I need an ODBC....or is it true I
can access a text file directly in this manner. The data is being
placed with all my other shapefiles (ie. in the same folder).
Also, can the .csv file just as easily be a .txt
file....and can the entries have quotations around them?
Kevin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070418/d2ccc60e/attachment.html
