Change Projection on-the-fly; Using PostGIS - How?
Stefan Schwarzer stefan.schwarzer at GRID.UNEP.CH
Fri Apr 20 05:02:47 EDT 2007
Hi there,
i am struggling since quite a while to set-up a change-projection-on-
the-fly possibility for our website mapserver. But somehow, I don't
really have the clue how to do it. Now, making things "worse" (more
complicated for me) we have migrated from MySql to Postgres/Postgis.
So, first question would be: What code to use to change the
projection via PHP/Mapscript, should be something like this, I guess:
$newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");
$latlon=ms_newprojectionObj("+proj=longlat +ellps=WGS84 +datum=WGS84
+no_defs");
$oldext=ms_newRectObj();
$oldext->setextent(-180,-90,180,90);  //this is the extent of my map
in geographic
$oldext->project($latlon,$newproj);  //reproject to Robinson
$map->setextent($oldext->minx,$oldext->miny,$oldext->maxx,$oldext-
 >maxy);  //set the new map extent
But I guess, something is still missing... (What about $map-
 >setProjection ?)
And the second question is: As my mapfile queries the postgis
database, using "SRID", I guess I need to change that one too, then?
Instead of 4326 for Geographic I would have to use the one for
Robinson (or Mollweide or so) ??
Thanks for giving me any hints...
Stef
