Change Projection on-the-fly; Using PostGIS - How?
Brent Wood
pcreso at PCRESO.COM
Fri Apr 20 06:29:32 EDT 2007
--- Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH> wrote:
> Hi there,
> i am struggling since quite a while to set-up a change-projection-on-
> the-fly possibility for our website mapserver. But somehow, I don't
> really have the clue how to do it. Now, making things "worse" (more
> complicated for me) we have migrated from MySql to Postgres/Postgis.
At least your spatial queries now have a chance of returning correct answers
The way I prefer to do this is to have the SQL thrown at Postgis do the
conversion, so mapserver doesn't have to. Thus:
select transform(the_geom, SRID)
instead of
select the_geom
But that's probably just because I have a SQL/database background, so tend to
do my work there. But it saves the wrestling with mapscript that you're going
through :-)
Cheers,
Brent Wood
> So, first question would be: What code to use to change the
> projection via PHP/Mapscript, should be something like this, I guess:
> $newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");
> $latlon=ms_newprojectionObj("+proj=longlat +ellps=WGS84 +datum=WGS84
> +no_defs");
> $oldext=ms_newRectObj();
> $oldext->setextent(-180,-90,180,90); //this is the extent of my map
> in geographic
> $oldext->project($latlon,$newproj); //reproject to Robinson
> $map->setextent($oldext->minx,$oldext->miny,$oldext->maxx,$oldext-
> >maxy); //set the new map extent
> But I guess, something is still missing... (What about $map-
> >setProjection ?)
> And the second question is: As my mapfile queries the postgis
> database, using "SRID", I guess I need to change that one too, then?
> Instead of 4326 for Geographic I would have to use the one for
> Robinson (or Mollweide or so) ??
> Thanks for giving me any hints...
> Stef
