What happend to OGR OVF layers since gdal 1.3.1
Huub Fleuren
hfl at HOME.NL
Wed Aug 1 12:06:27 EDT 2007
Hi List,
This is question about different gdal versions working on OVF layers
OGRINFO of any GDAL version gives me the data from such a layer using
ogrinfo layer.ovf -al
Versions 4.5, 4.8, 4.10.0 4.10.2 of mapserver compiled against gdal
1.3.1 work OKE but later GDAL versions give errors
layerdefinition
LAYER
NAME kpxy
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='kpxy'>
<SrcDataSource>ODBC:admin/admin at anwb</SrcDataSource>
<SrcSQL>SELECT k.kp_nr as kp_nr,k.x as x, k.y as y,
w.wegbeheerdercode as wegbeheerdercode, w.onderhoudsinstantiecode as
onderhoudsinstantiecode FROM wwall w, kpxy k WHERE NOT (k.soort LIKE
'D') and (w.x > %xmin%) and (w.x < %xmax%) and (w.y > %ymin%)
and (w.y < %ymax%) and (w.kruispuntnummer = k.kp_nr)</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding='PointFromColumns' x='x' y='y'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
DATA "kpxy" # the name of the OGRVrtLayer
etc.
errors
GDAL 1.3.2
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
<ServiceExceptionReport version="1.1.0">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'kpxy'.
msOGRFileNextShape(): OGR error. SetAttributeFilter() not supported on
ExecuteSQL() results.
</ServiceException>
</ServiceExceptionReport>
GDAL 1.4.2
<ServiceException>
'kpxy'.
msOGRFileNextShape(): OGR error. No column definitions found for table
'q_getBBoxAbonnement_1', layer not usable
</ServiceException>
I did not find documentation on changes concerning OVF layers. What
happened?
Regards, Huub
