Compiled MapScript for x64
Tamas Szekeres szekerest at GMAIL.COM
Sun Aug 5 07:04:10 EDT 2007
I recall we had a discussion about the x64 compilation and I copy the
link to the corresponding thread here, since it may apply to this
problem as well:
http://lists.umn.edu/cgi-bin/wa?A2=ind0701&L=mapserver-users&D=0&O=A&P=39484
It must be noted that the x64 version of mapserver/mapscript is not
thoroughly tested right now and we still have a pending issue about
the memory related problems with that.
http://trac.osgeo.org/mapserver/ticket/2023
Do you think you need a real 64bit image, or running the 32 bit
version on the 64 bit OS would also be sufficient?
Best regards,
Tamas Szekeres
2007/8/5, Jandost Khoso <interfacemirror at gmail.com>:
> Hi,
> Can anyone guide me how to get C sharp Mapscript assembly for x64 bit? i
> need to run my application on x64 bit computer but when i tried with x86
> compiled version in map server CGI folder it raises an exception about BAD
> LIBRARY IMAGE ( which implies it can not load the dll).
> Kindest Regards,
