question about WFS
Gregor Mosheh
gregor at HOSTGIS.COM
Mon Aug 6 11:41:05 EDT 2007
John B. Churchill wrote:
> I found a note on the Mapserver documentation which says that WFS-T is
> not supported by Mapserver. I suppose what I'm describing is
> something that requires a "transaction" and that I won't be able to
> do this with Mapserver.
Yep. Mapserver's WFS capability is read-only.
> One of the things I wanted to be able to do with the Mapserver WFS
> server that I've set up is allow people to add individual layers into
> their GIS software that they can then save
Yes, that's what the interoperability plugin was supposed to do, provide
a bridge to PostGIS. It sounds like just what you want. Are you unable
to install it, or is your ArcGIS too old, or what?
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
