MapServer Performance Tips
Timothy J Nolte tnolte at ILPCS.COM
Tue Aug 7 15:38:49 EDT 2007
Ok, the trick of all of this is that the data all comes from some MapInfo
source files. Actually they originate in an application call PlanetEV that
does grid analysis. I'm converting this data to contour shapefiles. I'd have
to go in and change about 2+ GBs of data. This is data that needs to be
updated manually every month. I want to try and make my update process as
quick as possible, however I do understand the need to make sure the data is
in the best possible format for server performance.
On Tue, 7 Aug 2007 13:08:00 -0500, Fawcett, David
<David.Fawcett at STATE.MN.US> wrote:
>Minimizing processing at runtime can only help.
>If you have the disk space and your data is static, you could pre-create
>different layers based on your expression criteria, so that your data
>doesn't have to be evaluated in five different layers.
>I don't know if it is still true, but regular expressions used to be
>faster than logical expressions, so you could add another column,
>pre-classify your data and store a class value in that column, something
>like a single-digit integer from 1-5.  That might evaluate faster than a
>complex logical expression.
