Using JOIN for querying
DrDik
richard.martin at TASCOMI.COM
Wed Aug 8 07:25:05 EDT 2007
Hi Maricris
I've read your posts in this problem and I have a question or two.
I've been
to your site:http://gis.pids.gov.ph/ and it's exactly what I need to
do!
Can you help?
I am using mapbender as the mapping frontend to mapserver. I have a
map
file much like yours... can you either email me or post your final
map file
and relater .html files? If you are able to I'll publish how I got
it all
to work with your help with a idiot guide and some dummy data - this
seems
to be a popular request without a definitive answer, but from your
site I
can see you got it working perfectly! Hopefully you'll be able to
help.
Many thanks
Richard
cris ricana wrote:
>> In the template file where the results should show, use the format
>> "[<join_name>_<fieldname>]" for dbf and mysql joins and
>> "[<join_name>_<fieldname>]" for csv joins. For example, I'm using
>> [reg_join_2] to access data from the 2nd column of my csv file.
> Correction:
> "[<join_name>_<fieldcolumn>]" for csv joins
> Maricris
View this message in context: http://www.nabble.com/Using-JOIN-for-querying-tf2187511.html#a12051321
Sent from the Mapserver - User mailing list archive at Nabble.com.
