QueryByAttribute on Mapinfo Tab files
mikiet mike.talbutt at DOTTEDEYES.COM
Wed Aug 8 03:41:13 EDT 2007
Hi, can someone give me some pointers please
I'm using Java mapscript to query a Mapinfo TAB layer in my map. Basically I
want to pick out all features in my mapinfo tab file that have an id of
"A00"
The layer is defined as follows
LAYER
NAME regions
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "C:/MapBase/regions.TAB"
STYLEITEM "AUTO"
TEMPLATE "ffff"
CLASS
  NAME "regions"
END
END
The code I have wrote is as follows
String columnName = "regionid";
String value = "A00";
System.out.println("query result = " + internalLayer.queryByAttributes(map,
columnName, value, mapscript.MS_MULTIPLE));
resultCacheObj resultCache = internalLayer.getResults();
System.out.println("resultCache.getNumresults() = " +
resultCache.getNumresults());
However when this code runs I always get the following output
query result = 1
resultCache.getNumresults() = 0
I have managed to do a queryByRect on the same layer and it is working fine,
so I presume its something to do with the parameters I am passing to
queryByAttributes method ?
Any advice greatly appreciated
View this message in context: http://www.nabble.com/QueryByAttribute-on-Mapinfo-Tab-files-tf4234712.html#a12048572
Sent from the Mapserver - User mailing list archive at Nabble.com.
