labelcache_map_edge_buffer
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Thu Aug 9 08:31:02 EDT 2007
Found it after reading the code a bit.
I had to add PARTIALS FALSE to get it to work.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde at OSGIS.NL>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-USERS] labelcache_map_edge_buffer
Datum: 09/08/07 09:56
> Hi list,
> I am trying to use the map edge buffer, but it has no effect, labels are
> placed closer than 100 pixels to the border of the image. How can this be?
I
> tried using both positive and negative values and added this to the WEB's
