MS 5.0b3 - AGG compile errors
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Fri Aug 10 11:18:03 EDT 2007
Stephen Woodbridge wrote:
>>> I created this  Ticket #2215: HowTo Build AGG with freetype support
>>> from sources, http://trac.osgeo.org/mapserver/ticket/2215
>>> Have a look it probably will help you for Linux and Jeff added some
>>> info on Windows. You will need to follow this if you do not install
>>> AGG as a distro package.
>>> -Steve W
>> I can't for the life of me find the Windows makefile.vc Jeff is
>> talking about in the info he added to the ticket. Neither the agg-2.4
>> nor the agg-2.5 source downloads seem to contain any such file and a
>> Google search turns up nothing either. Am I missing something here?
>> Any help is greatly appreciated.
>> Best regards,
> I know little to nothing about windows, but might that be the mapserver
> makefile.vc that Jeff was referring to? If not you have to catch Jeff
> McKenna for more info.
> -Steve
Thanks, Steve, the file I was looking for showed up as an attachment on
the Trac ticket right now. Seems Jeff had come up with it on his own and
now has kindly shared it with rest of us. Much appreciated.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi Str. 12
I 39100 Bolzano/Bozen
Phone:  +39 0471 068611
Fax:    +39 0471 068619
email: andreas.albarello at territoriumonline.com
web:   http://www.territoriumonline.com
