mapserver and arcinfo coverages
Laura Poggio
laura.poggio at GMAIL.COM
Fri Aug 10 12:20:10 EDT 2007
It is some days I am fighting with the possibility to "draw" arcinfo
coverages with mapserver.
Below there is the code I finally manage to write for the map file but it
does not work and I do not know how to solve it. I can "draw" raster and
shapefiles without problems, but not coverages
LAYER
NAME 'built'
DATA "D:/ALRPC/Gis/Data/Grugliasco/Ext/CTR/Vec/CoverageLP/gru_built"
TYPE polygon
STATUS OFF
CONNECTIONTYPE OGR
CONNECTION
"D:/ALRPC/Gis/Data/Grugliasco/Ext/CTR/Vec/CoverageLP/gru_built, 3"
CLASS
COLOR 255 0 0
END
END
The command I use to recall the map file in the browser page is:
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/tmp/mapfile/prova.map&layer=built&mode=map
If someone can help, thank you very much in advance
Laura
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070810/20e0bf52/attachment.html
