AGG Rendering with mapserver 5.0
Steve Smith ssteve52 at YAHOO.COM
Sat Aug 11 00:14:56 EDT 2007
The instructions below did not appear to help.
I tried installing the 32bit agg libraries into /usr/lib using the fedora package manager, and then re-configed and compiled mapserver. I was able to compile mapserver, but unfortunately the graphics still appear to be GD.
Steve
Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> wrote:   Ticket #2215: HowTo Build AGG with freetype support from sources,
http://trac.osgeo.org/mapserver/ticket/2215
Steve Smith wrote:
> I am attempting to use AGG with mapserver-5.0.0-beta3. I am using the
> following OUTPUTFORMAT statement in my .map file:
> OUTPUTFORMAT
>   NAME 'AGG_PNG'
>   DRIVER AGG/PNG
>   IMAGEMODE RGB
> END
> Is this correct?  The graphics do not look like AGG. Are there other
> statements in the .map file that could result in the use of GD graphics?
> I followed the explanations in:
> http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
> but, still no success. Configuring and compiling mapserver was
> successful. No errors occurred. I initially had a problem configuring
> with AGG, using libraries in /usr producing the following error message:
> checking if AGG support requested... configure: error: "could not find
> agg_rendering_buffer.h or libagg.a in /usr."
> I think this error was a result of my machine being 64 bit, which the
> current beta versions does not recognize. Things worked after I changed
> the directory to an AGG installation in /usr/local/agg.
> Steve
> Shape Yahoo! in your own image. Join our Network Research Panel today!
Yahoo! oneSearch: Finally,  mobile search that gives answers, not web links.
Need a vacation? Get great deals to amazing places on Yahoo! Travel.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070810/c631fc3a/attachment.html
