AGG Rendering with mapserver 5.0
thomas bonfort thomas.bonfort at GMAIL.COM
Sat Aug 11 03:10:37 EDT 2007
have you set IMAGETYPE AGG_PNG ?
On 8/11/07, Steve Smith <ssteve52 at yahoo.com> wrote:
> The instructions below did not appear to help.
> I tried installing the 32bit agg libraries into /usr/lib using the fedora
> package manager, and then re-configed and compiled mapserver. I was able to
> compile mapserver, but unfortunately the graphics still appear to be GD.
> Steve
> *Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>* wrote:
> Ticket #2215: HowTo Build AGG with freetype support from sources,
> http://trac.osgeo.org/mapserver/ticket/2215
> Steve Smith wrote:
> > I am attempting to use AGG with mapserver-5.0.0-beta3. I am using the
> > following OUTPUTFORMAT statement in my .map file:
> > OUTPUTFORMAT
> > NAME 'AGG_PNG'
> > DRIVER AGG/PNG
> > IMAGEMODE RGB
> > END
> > Is this correct? The graphics do not look like AGG. Are there other
> > statements in the .map file that could result in the use of GD graphics?
> > I followed the explanations in:
> > http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
> > but, still no success. Configuring and compiling mapserver was
> > successful. No errors occurred. I initially had a problem configuring
> > with AGG, using libraries in /usr producing the following error message:
> > checking if AGG support requested... configure: error: "could not find
> > agg_rendering_buffer.h or libagg.a in /usr."
> > I think this error was a result of my machine being 64 bit, which the
> > current beta versions does not recognize. Things worked after I changed
> > the directory to an AGG installation in /usr/local/agg.
> > Steve
> > Shape Yahoo! in your own image. Join our Network Research Panel today!
> Yahoo! oneSearch: Finally, mobile search that gives answers<http://us.rd.yahoo.com/evt=48252/*http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC>,
> not web links.
> Need a vacation? Get great deals to amazing places
> <http://us.rd.yahoo.com/evt=48256/*http://travel.yahoo.com/;_ylc=X3oDMTFhN2hucjlpBF9TAzk3NDA3NTg5BHBvcwM1BHNlYwNncm91cHMEc2xrA2VtYWlsLW5jbQ-->on
> Yahoo! Travel.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070811/bf4f08b6/attachment.html
