customizing epsg codes
Christopher Schmidt
crschmidt at METACARTA.COM
Wed Aug 15 12:45:52 EDT 2007
On Wed, Aug 15, 2007 at 10:33:13AM -0600, Gregor Mosheh wrote:
> >msBuildWMSLayerURL(): WMS connection error. Layer must have an EPSG or
> >AUTO projection code (in its PROJECTION object or wms_srs metadata)
> >Can't I include the IAU2000 codes somewhere in my proj setup?
> You sure can.
> Pop open the "epsg" file in your PROJ installation, e.g.
> /usr/share/proj/epsg
> Add a new record containing your projection's setting and your choice of
> EPSG code. EPSG codes above 1000000 are reserved for this sort of thing.
> Then use the projection as usual:
> PROJECTION
> "init=epsg:1234567"
> END
Note that, so far as I can tell, there is no way to cause MapServer to
accept the IAU2000:49900 code -- you'll have to create a 'fake' EPSG
code. AFAIK.
Regards,
Christopher Schmidt
MetaCarta
