Change Text of Feature Object/Inline Feature
ClackJim
jimlug at CO.CLACKAMAS.OR.US
Thu Aug 16 11:16:28 EDT 2007
Aloha folks,
I am trying to change the text of a so-called Feature Object using
MapScript. When I have the code within the MapFile, everything works just
fine. However, when I try to use MapScript I am unable to change the text.
I've tried several different techniques and searched all over for the
answer. Attached is a sample of my code within my MapFile:
#---Copyright---#
LAYER
NAME copyright
STATUS ON
TYPE annotation
TRANSFORM false
FEATURE
POINTS
70 535
END
TEXT "© Clackamas County 2006"
END
CLASS
LABEL
FONT arial
TYPE TRUETYPE
SIZE 8
BUFFER 1
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
FORCE TRUE
END
END
END
$coLyr = $map->getLayerByName('copyright');
$coShp =$coLyr->getShape(-1,0);
$coText = $coShp->text;
echo $coText . "</br>";
$coNewText = "©" . "Clackamas County 2006 - Aerial 2005" ;
$coShp->set('text',$coNewText); $coText = $coShp->text; echo "New text is "
. $coText;
I thought this should work since I am verifying the new text with the second
echo. Does anyone have any suggestion?
View this message in context: http://www.nabble.com/Change-Text-of-Feature-Object-Inline-Feature-tf4280302.html#a12183304
Sent from the Mapserver - User mailing list archive at Nabble.com.
