Strange MS beta3 behaviour..
Sture Dingsøyr
candalt at ONLINE.NO
Fri Aug 17 04:30:50 EDT 2007
Some more info regarding the strange problem of php using long time to finish rendering page...
Used Wget to demonstrate what is happening:
C:\Wget>wget http://avsdi:81/test.php
--10:16:59-- http://avsdi:81/test.php
=> `test.php.3'
Connecting to avsdi:81... connected!
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
0K ->
10:17:00 (86.91 KB/s) - `test.php.3' saved [89]
In this call the page is finished rendered in about 1 second... I have not enabled any Postgis or WMS layeres...
--10:17:06-- http://avsdi:81/test.php
=> `test.php.4'
0K ->
10:17:12 (18.00 B/s) - `test.php.4' saved [90]
In this call the page is finished rendered in about 6 second... Here a Postgis layer is enabled.
I can see that the MS picture is created in my tmp folder before the page is finished rendering...so the problem is the "extra" time the page "hangs".
Have also tested on a different computer, so I do not think this is a local problem...
Best Regards
-----Opprinnelig melding-----
Fra: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] På vegne av Daniel Morissette
Sendt: 16. august 2007 14:06
Til: MAPSERVER-USERS at LISTS.UMN.EDU
Emne: Re: [UMN_MAPSERVER-USERS] Strange MS beta3 behaviour..
Sture Dingsøyr wrote:
> Hello...
> Been testing the new beta release of MS4W (beta3), and i have noticed a strange behaviour.
> I use a small PHP mapscript to generate a picture. But when I use the mapscriptfunction "set("status", 1)" on a POSTGIS, WMS or WFS layer...the web browser "hangs" for many seconds before the PHP page is finished rendering.
> This behaviour dos not occur when "set("status", 1)" is used on a ESRI SHAPE or a RASTER layer.
This is definitely very strange. If you set "STATUS ON" directly in the mapfile then does it hang as well? If yes then that at least tells us that the problem has nothing to do with the set("status", 1) call.
Oh wait... those symptoms are similar to what we had in ticket #458
(http://trac.osgeo.org/mapserver/ticket/458) ... do you use DEBUG TRUE in your mapfile with MS_ERRORFILE "stderr"? If yes then perhaps try disabling it and see if that makes a difference.
Daniel
Daniel Morissette
http://www.mapgears.com/
