Strange MS beta3 behaviour..
Daniel Morissette dmorissette at MAPGEARS.COM
Mon Aug 20 08:43:52 EDT 2007
Thanks for tracking this one down. FYI I have filed a MS4W bug about this:
http://bugzilla.maptools.org/show_bug.cgi?id=1772
Hopefully the next release of MS4W will have this fixed.
Daniel
Sture Dingsøyr wrote:
> Solved the problem with php using long time to finish rendering page...
> I checked the PHP log and found this error message:
> [Fri Aug 17 11:15:03 2007] [error] [client 172.21.1.60] Error in my_thread_global_end(): 1 threads didn't exit\r
> A quick search lead me to:
> http://bugzilla.maptools.org/show_bug.cgi?id=1730
> It seams that php 5.2.2 and 5.2.3 have a broken libmysql.dll
> When I replaced the libmysql.dll in MS4W 2.2.5Beta with an older one from MS4W 2.2.3 the problem dissapeared...
> Hopefully this can help others having the same problem
> Cheers
> Sture
> -----Opprinnelig melding-----
> Fra: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] På vegne av Daniel Morissette
> Sendt: 16. august 2007 14:06
> Til: MAPSERVER-USERS at LISTS.UMN.EDU
> Emne: Re: [UMN_MAPSERVER-USERS] Strange MS beta3 behaviour..
>> Hello...
>> Been testing the new beta release of MS4W (beta3), and i have noticed a strange behaviour.
>> I use a small PHP mapscript to generate a picture. But when I use the mapscriptfunction "set("status", 1)" on a POSTGIS, WMS or WFS layer...the web browser "hangs" for many seconds before the PHP page is finished rendering.
>> This behaviour dos not occur when "set("status", 1)" is used on a ESRI SHAPE or a RASTER layer.
> This is definitely very strange. If you set "STATUS ON" directly in the mapfile then does it hang as well? If yes then that at least tells us that the problem has nothing to do with the set("status", 1) call.
> Oh wait... those symptoms are similar to what we had in ticket #458
> (http://trac.osgeo.org/mapserver/ticket/458) ... do you use DEBUG TRUE in your mapfile with MS_ERRORFILE "stderr"? If yes then perhaps try disabling it and see if that makes a difference.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
Daniel Morissette
