Add labelObj to a Class dynamically (C#)
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Aug 21 03:36:09 EDT 2007
You can modify the labelObj directly, it has already been created when
you created the classObj.
Umberto
On 8/21/07, Zhonghai Wang <zhonghaiw at gmail.com> wrote:
> Hi guys,
> I add a map layer with two classes on the fly to mapObj, for one class i
> need to use some customized label styles for the labeling. What surprised me
> is that I cannot insert or add a labelObj into a classObj, later I saw the
> doc for MapScript, seems that the classObj.label is a immutable property,
> which in C# is then readonly.
> Is it possible to add a labelObj to a classObj dynamically? or do the
> stylings with SLD for a windows application?
> Any comments are welcome.
> Best Regards
> Zhonghai
