PHP/Mapscript error - help needed
Gambin Dejan
Dejan.Gambin at PULA.HR
Tue Aug 21 09:46:35 EDT 2007
Frank,
Since I couldn't find gdal-config on my server and I needed it for
configure script, I have downloaded/compiled/installed 1.4.2 version of
gdal. After that I was able to install php/mapscript.
gdal-config --version says: 1.4.2
gdal-config --libs says: -L/usr/local/lib -lgdal
gdal-config --ogr-enabled says: yes
gdal-config --dep-libs says: -lodbc -lodbcinst -ljpeg -ltiff -lpng -lz
-lm -lrt -ldl -L/usr/lib -lcurl -L/usr/lib -lgssapi_krb5 -lkrb5
-lk5crypto -lkrb5support -lcom_err -lresolv -lidn -lssl -lcrypto -ldl
-lssl -lcrypto -lz
What are you suggesting me to do?
Thanks very much
regards, dejan
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Frank Warmerdam
> Sent: Tuesday, August 21, 2007 3:28 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript error - help needed
> Gambin Dejan wrote:
> > Hi,
> > Today I have upgraded my Apache to 2.0.55-4 version on
> Ubuntu server.
> > I have also installed php5 version 5.1.2. Since I was
> getting errors
> > about the incompatible API-s, I have recompiled
> php/mapscript from the
> > source (version 4.10.2). Everything was looking correct but
> after that
> > I am not being able to display anything on the map, it is
> blank. Then
> > I found the error message in apache error log saying:
> > /usr/sbin/apache2: symbol lookup error:
> > /usr/lib/php5/20051025/php_mapscript_410
> > .so: undefined symbol: _ZN13OGRLineString8setPointEidd
> > I can't find any information on this error...can someone help?
> Dejan,
> I believe this indicates an OGR version mismatch - likely php
> mapscript (in particular mapogr.cpp in the mapserver library)
> was built against a recent version of OGR include files which
> includes the 2D version of the setPoint() method while the
> actual libgdal.so being used at runtime is older and only
> contains the 3D version of setPoint() (with default parameter
> values for Z).
> You need to review what versions of GDAL/OGR you have on your
> system and ensure that MapServer gets built against the same
> version of GDAL/OGR as gets used at runtime. The most direct
> way to accomplish this is to ensure you only have one version
> of GDAL/OGR (.so, include files, etc).
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
