Error on Itemnquery with PostGIS-layer
HarryS mapcollect at GMX.NET
Tue Aug 21 10:41:40 EDT 2007
How could I add columns to DATA statement ?
I think my mistake is in the query-URL:
this one works on Windows with shapefile-data but not on Linux with PostGIS
(anything else works fine)
http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=name&qstring='London'
changing the syntax to this (what should be the same than above)
http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=name&qstring=('[name]'='London')
results in
msQueryByAttributes(): Search returned no results. No matching record(s)
found.
at least no error but 'London' is definetly in the database and I tried with
upper case/lower case,...
The PostGIS-databasename is 'geonamesallppl' the tablename is 'name' and
also the column-name is 'name'.
Any ideas what I am doing wrong ??
Thx, Harry
This is my template-file (if it plays a role)
<html>
  <head><title>Sample Template</title></head>
  <body>
     <li> Name is [NAME]
     <li> Population is [POPULATION]
     <li> Code is [CODE]
<tr>
  <td>[lrn]</td>
  <td>[NAME]</td>
</tr>
  </body>
</html>
Umberto Nicoletti wrote:
> Sorry, I meant the DATA statement.
> Umberto
> On 8/21/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
>> You probably have to add the columns in the CONNECTION STATEMENT.
>> Umberto
>> On 8/21/07, HarryS <mapcollect at gmx.net> wrote:
>> > this is the layer configuration:
>> > LAYER
>> >     NAME "City-Database"
>> >     GROUP "Databases"
>> >     STATUS default
>> >     DATA "the_geom from name"
>> >     CONNECTION "user=postgres dbname=geonamesallppl host=localhost
>> > port=5432"
>> >     CONNECTIONTYPE postgis
>> >     TYPE QUERY
>> >     CLASS
>> >       TEMPLATE "template-city.html"
>> >     END
>> >   METADATA
>> >    "queryable" "true"
>> >    "searchfield" "name"
>> >    "fields"
>> > "name:Name,population:Pop,country:Country,province:Province,CODE:Code"
>> >   END
>> >   END
>> > Mapserver can render maps using this layer and also searching via
>> > KaMap-Frontend works on this layer, only itemnquery via cgi gives me
>> the
>> > above quoted error. I tried using different cases with column names
>> (NAME,
>> > Name, name) but always got same error: ...ERROR: Column »london« does
>> not
>> > exist...
>> > This I don't understand because »london« is the querystring and not the
>> > column-name.
>> > Thanks,
>> > Harry
>> > > Please post the layer configuration for postgis AND check the case of
>> > > the column name.
>> > > Postgres handles column names with case sensitivity if, at table
>> > > creation, the column name was in quotes. In that case you have the
>> > > specify the column name with exactly the same case and in quotes;
>> this
>> > > is most likely the reason.
>> > > HTH,
>> > > Umberto
>> > >> doing this query:
>> http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=NAME&qstring='London'
>> > >> produces this Error:
>> > >> prepare_database(): Query error. Error executing POSTGIS DECLARE
>> (the
>> > >> actual
>> > >> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
>> > >> from name WHERE (London) and (the_geom && setSRID( 'BOX3D(-180
>> -90,180
>> > >> 90)'::BOX3D,find_srid('','name','the_geom') ))'
>> > >> Postgresql reports the error as 'FEHLER: Spalte »london« existiert
>> nicht
>> > >> (Translation: ERROR: Column »london« does not exist)
>> > >> More Help:
>> > >> Error with POSTGIS data variable. You specified '<check your .map
>> file>'.
>> > >> Standard ways of specifiying are :
>> > >> (1) 'geometry_column from geometry_table'
>> > >> (2) 'geometry_column from (<sub query>) as foo using unique <column
>> name>
>> > >> using SRID=<srid#>'
>> > >> Make sure you put in the 'using unique <column name>' and 'using
>> SRID=#'
>> > >> clauses in.
>> > >> For more help, please see
>> http://postgis.refractions.net/documentation/
>> > >> Mappostgis.c - version of Jan 23/2004.
>> > >> If I do the same query on the same layer but using a shapefile
>> instead of
>> > >> PostGIS for identical data the query works fine without any errors.
>> Can
>> > >> someone point me to my mistake, please ?
>> > >> Harry Schmidt
>> > >> View this message in context:
>> http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12250916
>> > >> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12252666
View this message in context: http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12255967
