Error on Itemnquery with PostGIS-layer
Sebastian Walter sebastian.walter at FU-BERLIN.DE
Tue Aug 21 12:12:40 EDT 2007
just a guess: you could try 'name.name' instead of just 'name'
(tablename.columnname).
Regards,
Sebastian
HarryS wrote:
> How could I add columns to DATA statement ?
> I think my mistake is in the query-URL:
> this one works on Windows with shapefile-data but not on Linux with PostGIS
> (anything else works fine)
> http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=name&qstring='London'
> changing the syntax to this (what should be the same than above)
> http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=name&qstring=('[name]'='London')
> results in
> msQueryByAttributes(): Search returned no results. No matching record(s)
> found.
> at least no error but 'London' is definetly in the database and I tried with
> upper case/lower case,...
> The PostGIS-databasename is 'geonamesallppl' the tablename is 'name' and
> also the column-name is 'name'.
> Any ideas what I am doing wrong ??
> Thx, Harry
> This is my template-file (if it plays a role)
> <html>
>   <head><title>Sample Template</title></head>
>   <body>
>      <li> Name is [NAME]
>      <li> Population is [POPULATION]
>      <li> Code is [CODE]
> <tr>
>   <td>[lrn]</td>
>   <td>[NAME]</td>
> </tr>
>   </body>
> </html>
> Umberto Nicoletti wrote:
>> Sorry, I meant the DATA statement.
>> Umberto
>> On 8/21/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
>>> You probably have to add the columns in the CONNECTION STATEMENT.
>>> Umberto
>>> On 8/21/07, HarryS <mapcollect at gmx.net> wrote:
>>>> this is the layer configuration:
>>>> LAYER
>>>>     NAME "City-Database"
>>>>     GROUP "Databases"
>>>>     STATUS default
>>>>     DATA "the_geom from name"
>>>>     CONNECTION "user=postgres dbname=geonamesallppl host=localhost
>>>> port=5432"
>>>>     CONNECTIONTYPE postgis
>>>>     TYPE QUERY
>>>>     CLASS
>>>>       TEMPLATE "template-city.html"
>>>>     END
>>>>   METADATA
>>>>    "queryable" "true"
>>>>    "searchfield" "name"
>>>>    "fields"
>>>> "name:Name,population:Pop,country:Country,province:Province,CODE:Code"
>>>>   END
>>>>   END
>>>> Mapserver can render maps using this layer and also searching via
>>>> KaMap-Frontend works on this layer, only itemnquery via cgi gives me
>>> the
>>>> above quoted error. I tried using different cases with column names
>>> (NAME,
>>>> Name, name) but always got same error: ...ERROR: Column »london« does
>>> not
>>>> exist...
>>>> This I don't understand because »london« is the querystring and not the
>>>> column-name.
>>>> Thanks,
>>>> Harry
>>>>> Please post the layer configuration for postgis AND check the case of
>>>>> the column name.
>>>>> Postgres handles column names with case sensitivity if, at table
>>>>> creation, the column name was in quotes. In that case you have the
>>>>> specify the column name with exactly the same case and in quotes;
>>> this
>>>>> is most likely the reason.
>>>>> HTH,
>>>>> Umberto
>>>>>> doing this query:
>>> http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=NAME&qstring='London'
>>>>>> produces this Error:
>>>>>> prepare_database(): Query error. Error executing POSTGIS DECLARE
>>> (the
>>>>>> actual
>>>>>> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
>>>>>> from name WHERE (London) and (the_geom && setSRID( 'BOX3D(-180
>>> -90,180
>>>>>> 90)'::BOX3D,find_srid('','name','the_geom') ))'
>>>>>> Postgresql reports the error as 'FEHLER: Spalte »london« existiert
>>> nicht
>>>>>> (Translation: ERROR: Column »london« does not exist)
>>>>>> More Help:
>>>>>> Error with POSTGIS data variable. You specified '<check your .map
>>> file>'.
>>>>>> Standard ways of specifiying are :
>>>>>> (1) 'geometry_column from geometry_table'
>>>>>> (2) 'geometry_column from (<sub query>) as foo using unique <column
>>> name>
>>>>>> using SRID=<srid#>'
>>>>>> Make sure you put in the 'using unique <column name>' and 'using
>>> SRID=#'
>>>>>> clauses in.
>>>>>> For more help, please see
>>> http://postgis.refractions.net/documentation/
>>>>>> Mappostgis.c - version of Jan 23/2004.
>>>>>> If I do the same query on the same layer but using a shapefile
>>> instead of
>>>>>> PostGIS for identical data the query works fine without any errors.
>>> Can
>>>>>> someone point me to my mistake, please ?
>>>>>> Harry Schmidt
>>>>>> View this message in context:
>>> http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12250916
>>>>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12252666
