Showing Movement Direction
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Aug 22 23:31:40 EDT 2007
Ben,
This is the same problem of displaying GPS tracks. They explicitly a set
of points, but when taken as a track over time they are a polyline. You
can not do anything with mapserver directly. You do have a few options:
1) write a script that adds heading column to each point, based on the
previous point and use this angle to orient a marker for the point.
2) load the data into postGIS and convert the points to a polyline and
either display it from postGIS or dump it back to a shapefile.
3) use postGIS to compute the heading column
4) other similar preprocess the data options
try search for "gps track" in both mapserver archives and postgis archives.
-Steve W
Ben Madin wrote:
> G'day all,
> I have been looking and reading, but I'm not sure I'm looking for the
> right thing.
> I have a number of points from satellite based tracking, giving me a
> list of longitude, latitude and a timestamp. These are fairly regular,
> and although I can display the points on the map window and see where
> animals have moved to, I can't tell which way they moved just by
> looking. We vets need to know what came first...
> So I thought I could convert adjacent points (temporally) into line
> segments, (earliest point first, latter point last), but I can't find
> anywhere in Mapserver that seem to explicitly explain how to do this (or
> whether it can be done).
> Can anyone either :
> direct me to the right place, or
> give me a set of keywords which might get me to the right place, or
> advise me to give up for now?
> cheers
> Ben
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome WA 6725
> ben at remoteinformation.com.au <mailto:ben at remoteinformation.com.au>
> Out here, it pays to know...
