HTML Legends + mapscript (Updated)
Bruno Maluche maluche at INF.UFSC.BR
Mon Aug 27 12:19:35 EDT 2007
Just added GROUP on my layer and It worked !
Thanks Tamas!
[]´s
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, August 24, 2007 3:41 PM
Subject: Re: [UMN_MAPSERVER-USERS] HTML Legends + mapscript (Updated)
Paul,
I've added a new C# example for testing processLegendTemplate in the SVN
trunk.
When doing the tests I've found the following issues and created a
ticket per issue:
http://trac.osgeo.org/mapserver/ticket/2261
http://trac.osgeo.org/mapserver/ticket/2262
I've fixed #2261 immediately but I leave #2262 for some other folks.
I'm not sure whether #2261 apply to your problem but the sample is
working for me with the current SVN trunk.
Best regards,
Tamas
2007/8/23, Paul james <pauljame at gmail.com>:
> Thank you Tamas....
> But, I´ve already read that discussion before and unfortunately I don´t
> known how It can help-me to make processLegendTemplate function works...
> If anyone have a sample using it, I will be very happy !  I´m stuck in
> that
> about 2 days ....
> I think my template html is fine... The only problem I think is that
> function that always return a empty string :( ...
> Ty very much again!
> On 8/23/07, Tamas Szekeres <szekerest at gmail.com> wrote:
> > Paul,
> > I recall I had a discussion about an issue like this a few months ago
> > in this list which can be found here:
> http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg11539.html
> > I'm not totally sure whether the statements out there apply to this
> > version exactly but this feature have been working that time pretty
> > well.
> > Best regards,
> > Tamas
> > > I created a template.html like that :
> > > [leg_class_html opt_flag=15]
> > > <img src=[leg_icon]> [leg_class_name] <br>
> > > [/leg_class_html]
> > > And in my mapfile:
> > > LEGEND
> > > STATUS ON
> > > KEYSIZE 18 12
> > > # LABEL object
> > > LABEL
> > > TYPE BITMAP
> > > SIZE MEDIUM
> > > COLOR 0 0 89
> > > END
> > > TEMPLATE "template.html"
> > > END
> > > Now, In code(c#) I´m trying to use processLegendTemplate function
> without
> > > sucess ... The function always return empty string ...
> > > I think I´m not using it correctly :
> > > string[] _x = new string[1];
> > > string [] _y = new string[1];
> > > string  _html = mapaObj.processLegendTemplate(_x, _y, 1);
> > > obs.: _html always return empty...
> > > Any ideas? I´m using Mapserver 5.0 beta 3 !
> > > []´s
> > > On 8/23/07, Paul james < pauljame at gmail.com> wrote:
> > > > Hello guys !
> > > > I need change my legend system (mapaObj.Legend()) drawwith HTML
> > > > legend
> > > > I´d like to known if someone could help me with that... Any samples
> using
> > > mapscript?
> > > > I´m completely  lost on this task!
> > > > Any help ?
> > > > Thx
