Article about MapServer 5.0
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Aug 28 10:40:08 EDT 2007
Note that there are two pre-defined output formats for AGG: AGGPNG24 and AGGJPEG. So it's
as simple as "IMAGETYPE AGGPNG24" now.
Steve
>>> On 8/28/2007 at 4:58 AM, in message <46D3F1AF.1070603 at mapgears.com>, Daniel
Morissette <dmorissette at MAPGEARS.COM> wrote:
> Thomas,
> When I first used AGG it was not obvious how to setup the outputformat.
> It would probably be a good idea to add those outputformat infos to your
> http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics page.
> Daniel
> thomas bonfort wrote:
>> Another question, I tested the new outputformat with AGG, is it
>> possible
>> to get jpg or gif image with it? If so, how can I setting up my mapfile
>> to realize this? Do I need special flag when building mapserver?
>> gif isn't supported with agg.
>> these are the main outputformats you can use with agg:
>> base outputformat, will output a 24 bit png:
>> OUTPUTFORMAT
>> NAME 'AGG'
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> END
>> 24 bit png, rendered on a transparent background:
>> OUTPUTFORMAT
>> NAME 'AGGA'
>> DRIVER AGG/PNG
>> IMAGEMODE RGBA
>> END
>> 24 bit jpeg output:
>> OUTPUTFORMAT
>> NAME 'AGG_JPEG'
>> DRIVER AGG/JPEG IMAGEMODE RGB
>> END
>> png output, with number of colors reduced with quantization:
>> OUTPUTFORMAT
>> NAME 'AGG_Q'
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> END
>> as for building, it will depend on your platform, but generally speaking
>> you'll run
>> ./configure [...] --with-agg=/usr [...] if you're using a distro build
>> of agg
>> or
>> ./configure [...] --with-agg=/path/to/agg-source [...] if you're using a
>> downloaded version from antigrain.com <http://antigrain.com> (you'll
>> have to build agg in the source directory before doing this. just
>> running 'make' should be enough)
>> happy to answer other questions if any (en francais aussi, si c'est plus
>> facile)
>> thomas
