GDAL failure in call from java mapscript
Howard Butler
hobu.inc at GMAIL.COM
Thu Aug 30 17:18:12 EDT 2007
Ben,
One suspicion I have is that you are running into this bug if the JVM
limits its stack sizes <http://trac.osgeo.org/gdal/ticket/1736>. Do
you happen to know what the default JVM stack size?
Howard
On Aug 30, 2007, at 3:53 PM, Ben Tuttle wrote:
> Hi all-
> We are doing some work with java mapscript and are running into some
> problems. This has worked fine for the most part. However, in one of
> our test cases we've come across what appears to be a bug, that in our
> case takes down the entire webserver. Any info on what might be
> causing our problem would be greatly appreciated.
> Here are the details:
> Windows XP, Mapserver 4.10, gdal1.4.1, Java 1.6, Tomcat 6.0
> MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> The bug arose when calling making a WMS request to Mapserver through
> tomcat. The following URLs succeed:
> https://wahlstrom-670/Dispatcher/wms.do?map=/boulder_data/
> bldr.map&REQUEST=GetMap&LAYERS=zoning_08_05,openspace09_05&TRANSPARENT
> =true&srs=EPSG:4326&bbox=-106,39.5,-105,40.5&format=image/
> png&VERSION=1.1.1&styles=&SERVICE=WMS
> gif&VERSION=1.1.1&styles=&SERVICE=WMS
> This one however fails catastrophically, taking down the webserver
> and the JVM
> tiff&VERSION=1.1.1&styles=&SERVICE=WMS
> Note that the only difference is that the format QS parameter has been
> changed from "image/png" to "image/tiff".
> To further debug this problem we wrote a simple java app to call
> mapscript :
> import java.io.*;
> import edu.umn.gis.mapscript.*;
> public class MapScriptTest {
> public static void main(String[] args) {
> try {
> OWSRequest req = new OWSRequest();
> req.setParameter( "SERVICE", "WMS");
> req.setParameter( "REQUEST", "GetMap");
> req.setParameter( "LAYERS", "US state boundaries");
> req.setParameter( "format", "image/tiff");
> req.setParameter( "version", "1.1.1");
> mapObj map = new mapObj("USA.map");
> mapscript.msIO_installStdoutToBuffer();
> int owsResult = map.OWSDispatch( req );
> mapscript.msIO_stripStdoutBufferContentType();
> byte[] resultBytes = mapscript.msIO_getStdoutBufferBytes
> FileOutputStream fou = new FileOutputStream(new File
> ("map.tiff"));
> fou.write(resultBytes);
> fou.flush();
> fou.close();
> } catch( Exception e ) {
> e.printStackTrace();
> Running this program on our system will generate a seg fault in
> gdal14.dll. Java reports the following:
> # An unexpected error has been detected by Java Runtime Environment:
> # EXCEPTION_STACK_OVERFLOW (0xc00000fd) at pc=0x0328dcb5,
> pid=1180, tid=3208
> # Java VM: Java HotSpot(TM) Client VM (1.6.0_02-b06 mixed mode,
> sharing)
> # Problematic frame:
> # C [gdal14.dll+0x24dcb5]
> # If you would like to submit a bug report, please visit:
> # http://java.sun.com/webapps/bugreport/crash.jsp
> We can repro this on both prebuilt binaries and ones I build ourself.
> There are some files for a small re-pro program at
> http://www.waterstoneinc.com/7e70820538e2ea58949752422edbdaf6/:
> · MapScriptTest.java – Simple driver java program
> · HelloWorld.map – Simple example map
> · Mapscript.dll – The mapscript DLL I'm using. Feel free to
> use your own
> · buildAndRun.cmd – a cmd file to compile the java code and
> run it with four sets of sample parameters. The last of which will
> cause the seg fault.
> Note: you will likely need to edit buildAndRun.cmd to make sure you
> are adding all the referenced mapscript DLLs to your path.
